跳转到主内容
加入维修社区 - 创建账户
本设备于 2014 年 9 月 9 日发布,是 Apple 首次尝试进入智能可穿戴设备领域的产品。iFixit 的维修手册适用于 Apple Watch(不锈钢版)和 Apple Watch Sport(铝金属版)。
Apple Logo Appears Only Once When Plugged In
Hello everyone!
First of all, I do not know which version of Apple Watch this is. Someone gave it to me, but did not tell me which model it is. I believe it is an Apple Watch SE, but I am honestly not sure.
Well, the Watch simply does not turn on. When I connect it to the MagSafe Charger, I see the Apple Logo for about half a second, and then it disappears. If I play with the buttons a little bit, sometimes I can get it to turn back on... but the Watch itself I cannot get to boot. I would think this is either and issue with the battery or the button itself. Since I have little to no experience with the Apple Watch, I figured I would like to hear from you guys before I get inside. What do you guys think this issue is?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论:
Hi @jadonlyon
Check on the back of the watch as all the information regarding model etc should be printed on there
由完成的
42mm case • 7000 series aluminum • ion-x glass • composite back • serial fh7r6blzg9j
由完成的
@jayeff - I am not sure if this helps
由完成的
@jadonlyon
7000 series indicates that it is the original Apple watch i.e. the very 1st one released. Not to be confused with an Apple Series 1 watch which came next.
ifixit still has some parts for it but not many.
由完成的
@jayeff - Oh, that's old....
由完成的
添加一条评论
2个答案
@jadonlyon
Yeah.
Given its age most likely it is a battery problem if it has never been replaced and if it hasn't been charged for a long while.
Update (12/21/24)
@jadonlyon
I've changed the device you selected for your question to the correct one for the model.
Click on the Apple watch - original icon (to the right of your question) to see the ifixit repair guide.
Cheers
这个答案有帮助吗?
得分 0
2条评论:
@jayeff - Then I will check that first. Thank you!
由完成的
@jayeff - Thank you so much!
由完成的
添加一条评论
Here’s the guide to replace the battery 更换苹果手表的电池 iFixit still has replacement batteries for this series. Make sure you get the kit as you do need a few other parts s well.
这个答案有帮助吗?
得分 0
1条评论:
@danj - Thanks for this info
由完成的
添加一条评论
添加你的答案
Jadon Lyon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 361
