跳转到主内容
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
My controller's joystick overshoots under the slightest touch.
Hello. Recently I discovered that my ps4 controller overshoots a lot. This happens in the left joystick and only if I push it slightly up.Not down,left,right. If I push it up a bit more it starts working normally again from all directions. Is there a fix for this? Please let me know the problem and the fix if possible. Thanks a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi!
Do you mean that you are experiencing drift? If yes, then I'm afraid you need to replace the joystick. This can be difficult, as it's soldered on the motherboard.
Here you can find how to do it: DualShock 4左遥控杆维修
While you are there, it's recommended to replace it for a Hall Effect joystick!
Please let us know how it goes!
这个答案有帮助吗?
得分 3
5条评论:
@dan0 Hello thanks for the answer. I don't think it's drift as it doesn't move by itself,only when I push it up slightly, it pinches all the way up and stutters. If I push it up a bit more, it starts working normally again.Is that considered drift? I'll replace the joystick and let you know.
完成的
Could be yes, it's recommended to replace it anyway and see how that goes! Please let us know if it worked or not.
完成的
@dan0 THANK YOU A LOT!!! TURNS OUT THE LITTLE POTENTIOMETER WAS SCRATCHED AND MADE THE CONTROLLER MALFUNCTION, REPLACING THE JOYSTICK DID THE TRICK!! AGAIN THANK YOU A LOT!!!!!!
完成的
Ahh good to hear that you have fixed it :)!
My pleasure! Have fun gaming and take care!!
完成的
@dan0 You too!!!!:)
完成的
添加一条评论
添加你的答案
Evi Matz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 132
