跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Boot Loop and battery not charging
Hi, I have used iphone 3GS model-A1303. I haven't used it for a long time and when i recently tried to turn it on it first displayed a battery flat icon and later it showed me the apple logo and then turned off. I charged it for 4hrs and still the same. So I enabled DFU mode and itunes recognized the device and when i tried to restore it posted that the device was previously in DFU mode now it has been restarted but my device is still in DFU mode. I suspect that this is a battery issue but before buying a new battery i need to make sure that the device is in working state. is there any way to find that or boot into device without battery. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This sounds strongly like a battery issue to me. In my experience. I have never known and iPhone to boot without a good battery unless you have the ability to connect a power supply directly to the logic board (via the battery connector).
Unfortunately, you'll likely have to get a good battery in it to get it to power on. The fact that it has responded to everything else though is good because it sounds like the system is functioning properly. Just needs a good power source.
这个答案有帮助吗?
得分 1
1条评论:
@flannelist , ok i’ll try to get a new battery. Thanks for the help.
完成的
添加一条评论
添加你的答案
4072_Prasanth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 233
