跳转到主内容
加入维修社区 - 创建账户
一款任天堂为 Switch 系统生产的无线、传统的视频游戏手柄。型号:HAC-013。
Botched Pro Controller Joystick Replacement - Is it salveable?
Hi everyone, I tried to replace the left joystick on my Nintendo Switch Pro Controller. Unfortunately, as the title says, I botched it. I managed to desolder most of the solder points for the joystick, but I still couldn't detach it.
In the process of trying to get any residual solder off the mounting pads, I partially ripped one of them. I think I need to get solder flux to try to get the remaining solder to flow to detach the joystick. However, I want to get the opinion of those more experienced to find out if I passed the point of no return before proceeding. Pictures are below.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
is it the bottom left in the photo
这个答案有帮助吗?
得分 0
2条评论:
Yes it is. You can see the torn pad on the right side of the mounting points in the bottom left of the picture.
完成的
@smoothbrain looks similar to the pins above so i would say its a ground pin and fine to connect both together, so the bottom pin to the 1 just above with either a jumper wire or solder blob which ever is easier for you to do
完成的
添加一条评论
添加你的答案
smoothbrain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 322
