跳转到主内容
加入维修社区 - 创建账户
型号 A1502 / 2.6 GHz(睿频最高可达 3.1 GHz)或 2.8 GHz(睿频最高可达 3.3 GHz)双核 Intel Core i7 处理器,配备 4MB 共享三级缓存。
HDD needs to be formatted
Hello everyone!
My daughter by accident (she said that) interrupt an update of her old Mac book pro (A1502) and she got a new and I would like to install Linux in it, but during the process the HDD couldn't be accessible or formatted, what can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@jesussalin4792 - Can you first tell us the model and year as different series have different requirements.
完成的
Model A1502 we got it in 2014 and I forgot to say that it doesn't have any utility load it in the HDD.
Than you I really apreciate your help.
完成的
添加一条评论
1个答案
Technically speaking this system has a SSD not a HDD. You should be able to access the Apple OS recovery server to at least get macOS installed again. As you need to can access to the disk utility tool it offers. Now the tricky part you need to partition the drive into two partitions the first is where macOS sits I would make is around 40GB so you have some space besides the OS and it’s needed virtual RAM space. Then you can create the second partition for Linux and do the install within it. The needed Startup command is Option-Command-R and here’s the full write up on the commands: Mac startup key combinations
To speed up the process you could leverage her new Mac but you will need to access the OS installer file directly from Apples server How to download and install macOS but the highest you can run is Big Sur on this older system download it. Then connecting the two systems together via a Thunderbolt cable you can enable Target Disk Mode Transfer files between two Mac computers using target disk mode if you don’t have a cable grab a 32GB USB thumb drive and reformat it to GUID and a journaled file system then copy the OS installer to it and then convert it to a bootable installer by following this guide Create a bootable installer for macOS
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesus Salinas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 219
