Where is the actual power ic? - Solved
i have had this similar problem, it took alot to repair though, i replaced the battery, charging dock and i reflowed the board, this worked for me, and where is the actual power ic?
If you actually do need to replace this I.C. the cheapest place to buy a replacement from would be here.
Power Supply IC Chip For iPhone 4
Unless you are trained in replacing an I.C. I would recommend asking Hector Hector's Profile
He is a Guru at soldering.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 13,029
1条评论
thank you alot, my friend, you are awesome, thanks to you got the repair done with and the customer was extremly pleased, thanks again
由 Krayzee 完成的
