跳转到主内容
加入维修社区 - 创建账户
Samsung 于 2019 年 2 月发布了新版 Galaxy Tab A 10.1。该设备搭载 Android 9.0 Pie 系统(可升级至 Android 10 和 11),配备 Exynos 7904 芯片组,并采用分辨率不变的 IPS 显示屏。相比前代,该型号取消了后置闪光灯,去掉了 S-Pen 支持,电池容量更小,但前置摄像头升级为 500 万像素,且扬声器现已支持立体声。 型号:SM-T515 和 SM-T510。
USB cable transfer to computer not working
I initially had the problem where it says there is moisture in the charging port
and will not turn on. I took it to a repair shop and he replaced the charging
port board. Then it worked alright for a while but now it has stopped working
when I want to transfer files between the computer and tablet via USB cable.
Windows says the device attached is malfunctioning. The tablet still charges
properly though (and normal charge not slow). So could this be a problem with
the connection between the charging port board and the motherboard or the
USB connector on the tablet? In either case maybe I could just take it apart
and clean it up myself? I have a fairly good knowledge of electronics but not
much experience in maintenance. I would be most grateful for any advice
anyone can give me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
have you checked that the USB cable is capable of transmitting information and not just current. If there is a genuine problem with the tablet and not the cable you probably need to change the USB port here is a guide Samsung Galaxy Tab A (2019) 充电口更换
这个答案有帮助吗?
得分 1
添加一条评论
Hello there,
Thanks for your input. I diagnosed that it was indeed the table in the end by connecting my phone to the computer using the same cable and transferring files worked. I had the charging port replaced last year by a repair shop and did not want to have to keep doing it as it costs £60 and you can just buy another tablet for that. Similarly doing it myself will cost £30 in tools and a lot of time and effort. Also the last time I did that was taking a PS/3 apart and when I put it back together the WIFI ceased to work! Admittedly now I have found this site future operations should be a lot less hazardous :-)
In the end I had an idea which is to remove the MicroSD from the tablet and plug it into the computer via a USB/MicroSD adapter I had hanging around. It is transferring 30Gb right now and looks like it will finish in 20 minutes: would have taken over a week via Bluetooth!
Anyway thankyou again for your help.
Regards
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lori Fairhead 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 266
