跳转到主内容
2015款 Nintendo 3DS XL,也被称为新 Nintendo 3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
Console turns on with blue light screens light up nothing displays
Hi all I have recently acquired a new nintendo 3ds xl which I have been told it was working last year then got put away and now won't start/boot when I try to turn it on it shows a blue power light and screens both light up but nothing displays on them I has no cfw installed and dosnt have any kind of water damage and everthink looks very clean on the inside boards I have tried recommended steps from online like remove battery sd card ect reconnecting cables ect and have tried recovery mode by pressing L+R UP on dpad and a button when powering on but nothing changes other than a separate orange light appears near the blue power light I've also tried switching it on and leaving it for 15 mins to see if it boots but still nothing and was hoping someone might have seen this before and might have some suggestions any help is really appreciated and thankyou for you time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Are you like 100% sure that it’s not modded??
Anyway, please remove the SD card and try to boot it without one. This error could be caused by anything. Even by the camera ribbon cable.
Please check if the above didn’t worked, all the ribbon cables for damage and if they are properly connected.
这个答案有帮助吗?
得分 1
10条评论:
Hi thankyou for you comment as far as I know it isn't modded and I have tried removing sd card and booting but still nothing. there is a very slight bulge to the battery but it charges and dose power on I have also tried my non xl 3ds battery by holding it in place as its smaller but the same thing happens unfortunately I have also removed all cables and boards to check it all looks ok but I wouldn't know what to look for for a broken ribbon cable other that physical damage and they look ok to me
完成的
Hi!
I think this is not related to the battery, so that should be fine. Maybe this is software related. @darthmango know more about this! If it’s hardware related anyway, we need to check invidual components. But hopefully it is software related!
完成的
@dan0 hi thankyou for the reply I've disconnected all leads and cables to check them over they all look good to me but I am no expert all boards look clean aswell I hoping this is software related aswell.
完成的
No problem! Let’s wait for @darthmango. Otherwise we do need to check invidual components.
完成的
@dan0 I will do thankyou buddy while we wait how would I go about checking each component I do have a multimeter if this helps but I've never used it so I'm not too sure how these work thanks again
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Beastmanlee36 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 243
