跳转到主内容
The Ridgid R3203 Circular Saw is a corded electric saw with a 6-1/2 inch blade capable of reaching speeds of 6,100 RPM. This page offers detailed information and repair guidance for this 8 lb saw, including its specific cutting depths at various angles and other technical specifications.
Why won't my blade turn
  • Why won't my blade turn
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@bey63521 there are lots of reason why this could be. Check the switch and the power cable. Make sure those are working and that the cable shows continuity. Next check the motor. Make sure that you have continuity between the switch and the motor with the trigger switch pulled.
Next, you will need to see if the motor still turns or if it is seized. Can you easily move the blade by hand? Next, check the carbon brushes, make sure those are in good working order.
So, as you can see, lots of things to check. For all of those tests, you do have to unplug the power cable from the outlet.
If you are having issues with checking any of this, let us know. We can probably guide you a bit better but we have to see what you have going on there. Be ready to take some good pictures and get a multimeter so we can have you do some checks.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 70
