跳转到主内容
加入维修社区 - 创建账户
Rears break light doesn't turn on
Rear break light doesn't turn on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hello San.
We are going to need more information about what happened.
What happens when you press the brake?
This is most likely a blown fuse, faulty connector or a faulty break light sensor.
完成的
添加一条评论
2个答案
最有帮助的答案
@san38951 the very first thing you want to check all the fuses, the bulbs and the sockets for good connections. Next in line is your brake light switch. It is located under left side of dash, at the top of brake pedal. It's #3 in this image
Make sure that the plunger of the switch engages or disengage with the movement of the brake pedal. You can also use a multimeter or test light to see if the switch actually activates (closes contacts) when you depress the brake pedal. Because of the location of the switch it's a PITA to work on this but it is not to complicated. Of course, you always want to check all the fuses, the bulbs and the sockets for good connections.
这个答案有帮助吗?
得分 2
添加一条评论
السلام عليكم
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
San 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 193
