跳转到主内容
加入维修社区 - 创建账户
FixHub 便携式电源站的维修和故障排除信息,该便携式电源站是 iFixit 的 FixHub 产品线的主要电源和控制界面。于 2024 年 10 月发布。
Factory reset, CLI serial commands
Hi, does anyone know a command to return the FixHub to it's original shipped state?
Am thinking this would be via a terminal session, as the "knob" doesn't seem to show this option.
Also, is there any documentation on the CLI serial commands?
Some, like mcu-sn or toolinfo, are fairly straightforward, but am wondering if there's a comprehensive list of the other commands, similar to a man page.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Hi @osxtra ,
There is no menu setting on the Power Station to reset factory defaults, nor is there on the web interface (currently).
In the meantime, these are the default settings:
Language (English)
Power-Off Timer (10 min)
Timer Enable (Enable)
Max Charge (100%)
Error Log (clear error log)
We also don't currently have a public spec for the serial terminal commands. We might in the future.
这个答案有帮助吗?
得分 1
5条评论:
Tanks for the info, Kris!
完成的
I do not see the option "Max Charge" in my menu. Is this part of an update?
完成的
@omegatotal Yes, you should be able to see this option once the firmware is updated (not sure what exact firmware version number this would be when this option first appeared).
完成的
Nice 6 month turnaround
完成的
omegatotal, I see your 6 month turnaround and offer a seven.5 month one in return: ;)
CLI commands and STL files for the hub and irons can be found on iFixit's GitHub site:
https://github.com/iFixit/FixHub
完成的
添加一条评论
添加你的答案
osxtra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 528
