跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
Will restore erase all of my music?
If you restore your ipod will it erase all of your music on the ipod? and if so, do you have to restore it? thanks heaaaaaps tho!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Yes it will. If you have to do a restore, depends what's wrong with your iPod. The trick would be to either have it backed up before ;) or get a USB to ZIF adapter, remove your hard drive and copy your files with some of the freeware that is out there (depends on your OS) to your computer. Then restore your iPod and reload the music. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
If you want to get back your erase all of your music. Well Lots of iPod music recovery software are available in the market. But reason is that how to recovers and restore my erase or deleted Files. I used one the best iPod music recovery this software very user friendly and no need technical experience. It can easy to use the software. Kernel Recovery for iPod software recovers all erase or corrupt music very small minutes.
这个答案有帮助吗?
得分 0
添加一条评论
Really Kernel for iPod Data Recovery Tool is more advance or effective software. It can quickly & easily recover all lost, corrupted, accidentally deleted audio and videos song. The free demo version also available. click here :
这个答案有帮助吗?
得分 0
添加一条评论
Yes it will. If you restore your ipod, it will erase all of your music on the ipod. But you don't need to worry about that. Only if you sync the music files to iTunes, the problem that how to recover music from iPod seems simple after you restore your iPod. You can use Data Recovery software to help you restore music files. It can recover all the music files in a few minutes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Renee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 16,296
