跳转到主内容
加入维修社区 - 创建账户
飞利浦唤醒灯闹钟,带彩色日出模拟、5 种自然音效及收音机功能。2017 年 4 月发布。型号:HF3520/60。
How to fix lamp always on?
I bought a HF3520 second hand, and everything works fine except that whenever the lamp should be totally off it is at full brightness.
For instance, if I press the lamp button the lamp turns to however bright/dim I've set it, but if I press it again it turns to full brightness.
I've tried disconecting it for a while, and reseting it but nothing has worked.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you review the owners manual? Here’s where you can download load it HF3520 info
I’m suspecting the settings are off either AM - PM confused or the time zone setting.
这个答案有帮助吗?
得分 0
6条评论:
Thanks for the reply!
I checked the manual. I changed the time setting and that didn't fix the issue, also the lamp function should be able to be turned on and off regardless of the time.
由完成的
@ericastrue - Then the switch is bad or the logic which controls the lamp.
I have HomeKit version of the lamp and have it programed with Siri as well via my HomePod Mini. My first unit was defective as the control logic was bad.
由完成的
I see, maybe it's a different model as with mine I don't think I can conect the device with other devices.
由完成的
@ericastrue - Sorry, I may have confused you. If the settings are correct then it’s the switch or the logic which controls the light. Best to find someone with micro electronics skills to help you locally.
由完成的
Someone on reddit told me about having a similar issue, and in his case it was a fawlty capacitor. I've dissassembled the light today and I've found that that same capacitor has a slight bulge on the top in my unit. I'll try to test it tomorrow and replace it, and I'll get back to this thread.
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
Eric Astrue 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 42
总计 490
