跳转到主内容
加入维修社区 - 创建账户
2020 年 5 月发布的 13 英寸 MacBook Pro 搭载了四核 Intel 第八代 Core i5 和 i7 处理器,以及 Intel Iris Plus 645 核芯显卡。(型号 A2289/EMC3456,配备两个 Thunderbolt 3 端口)
How do I replace the camera?
My camera is not working, can someone explain how to replace it please. The green light comes on but no image
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
8条评论:
Not sure what happened. I posted an answer here and I was notified that you commented on my answer. However, my answer is nowhere to be found now.
完成的
@wenchao - It was deleted as your answer is a very different setup with the older Unibody systems.
完成的
@danj Sorry about that, but the basic troubleshooting princle shall apply: make sure it's the camera by testing another assembly before proceeding the difficult part of replacing it.
完成的
@wenchao - Apple makes testing on the there M series very difficult at the physical level. At best you have the onboard diagnostics.
Replacing is not really done, here the full display assembly is swapped out as the lid assembly is not easily opened and replacing the camera is just not done.the camera is serialize to the system.
完成的
@danj "the camera is serialize to the system" does it mean the replacement camera wouldn't work?
I knew that a few iPhone componenets were binded to the system such as touch ID, which many people complained about. What good does it do for Apple?
完成的
显示更多的3条评论
添加一条评论
3个答案
Start by resetting the NVRAM and SMC. If that doesn't help, then you know you have a hardware issue with the display. Replacing the camera itself on these models is not easily done. You would need to fully disassemble the display assembly and do some very delicate microsoldering. The more feasible approach is to replace the display assembly, but the displays on these can be pretty expensive. Here's a link to a display. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
Is this the original display that came with the system?
这个答案有帮助吗?
得分 0
添加一条评论
You might be better off just using an external web cam when necessary as the 'repair' to fix the possibly damaged camera is a nightmare of a job when it comes to removing the screen glass and all to get to the camera part...... Have you checked inside that all the cables are in place..... 2020年款带两个Thunderbolt端口的13寸MacBook Pro 显示屏总成更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ronald León 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 31
总计 589
