跳转到主内容
加入维修社区 - 创建账户
T460 是 T460 系列三款笔记本电脑中的标准款,均于 2016 年 2 月由 Lenovo 发布。
Repetitive crashes and freezing relating to SSD
I've had this laptop for less than a year and I've barely used it. I keep getting these crashes and blue-screens (and occasionally a yellow-screen) suddenly and for no reason. I could be staring at my desktop and it'll hit me with a blue-screen and start beeping. I get an error screen sometimes with the message "Detecton error on SSD (M.2)." Whenever these crashes happen it takes a while for me to boot it back up. It usually forces me to open Lenovo Diagnostics on startup. I tried taking apart the laptop to ensure that the SSD isn't loose. The manual isn't very good so I couldn't even find it. What's my next move?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @thedukkofcode
What does Lenovo diagnostics mentioned about SSD health?
Two possible fault which i can think of.
1. SSD is failing
2. Mainboard having some issues / connector issues.
If it is still under warranty, consider to get check by Lenovo.
完成的
Thank you for your comment, @salmonjapan
I’ve ran every extended test in Lenovo diagnostics and they all passed. Leaving me even more confused.
完成的
添加一条评论
1个答案
已选择的解决方案
I opened up the laptop, took out the SSD, and placed it back in. Since these crashes were happening multiple times per hour, it’s safe to say the issue is now fixed. Vibrations or dust could’ve affected the connection and reseating it reset that connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dukk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 438
