跳转到主内容
加入维修社区 - 创建账户
苹果 iPod Touch 系列的第七代产品,于 2019 年 5 月发布。该型号最高配备 256 GB 存储空间和 A10 处理器。型号为 A2178。
Battery removal is never mentioned
In all of the answers after step 22 -all the guides instruct to set aside the battery to the left. None of them say actually how to remove the battery in full.
How it is done? Thanks all- I just need to service the battery.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The battery is soldered to th logic board, so you’ll need to have some basic command of soldering to remove it and replace with a new one.
If you have a look at the battery, it’s not like the other components that have a connector which snaps into something on the board. There is some tape covering the contacts on the board. You’ll need to desolder the connector here and solder on a new battery.
Replace a battery compatible with a 6th or 7th generation iPod touch model A1574 or A2178. Part #020-00425. Battery Model #A1641. 3.83 Volts (V).图片
产品
iPod touch (6th and 7th Gen) Battery
$19.99
这个答案有帮助吗?
得分 4
1条评论:
Thanks- Fix-ability of this product seems low- I might not tackle it.
由完成的
添加一条评论
添加你的答案
Paolo Alberto 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 40
总计 505
