跳转到主内容
Clothes dryer repair and support guides.
748 个问题 查看全部
What does the F41 code mean on a Kenmore Oasis Elite dryer
What does the code F41 mean on my dryer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Kenmore elite oasis dryer reading f41 thanks
完成的
添加一条评论
2个答案
最有帮助的答案
My dryer (Kenmore Elite Oasis Canyon) also had the same error code flashing F 41. After dismantling and troubleshooting, the problem was in the blower motor. The problem was a baby sock had made it past the lint screen and got hung up in the impelor of the blower assembly. no parts needed replaced, just removed sock, put everything back together, dryer is working fine. just thought i'd add my experience to hopefully help out the next guy.
这个答案有帮助吗?
得分 2
1条评论:
I had the same problem. One of the face masks slid through the lint screen and in to the blower fan. I had to disassemble the front and feel my way to the blower fan to pull it out. Your answer helped me fix it! Thanks!
完成的
添加一条评论
Deedee, "the "F41" flashes when there is Blower Motor failure or if the fuse in the circuit between the machine control board and the motor control board failed . The inline fuse in located in the blue wire between the P9-1 connector and L1 on the motor control board. Diagrams for your dryer are available right here. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deedee 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 109
总计 9,580
