跳转到主内容
Repair documentation and service information for Hisense televisions.
20 个问题 查看全部
Why My TV went blank and the audio is still on
My brother was watching the TV, its actually connected to the internet and all of a sudden it went blank and the audio was still on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@bukayo start of by letting us know the exact model number for your Hisense Tv. Next, try a couple of basic things. Turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see.
Let us know what you find out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bukayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 11
