跳转到主内容
Repair guides and support for Canon's EOS Rebel XSi. This is a DSLR camera with a 12.2 MP sensor released in 2008. Also known as the EOS 450D and the EOS Kiss X2.
20 个问题 查看全部
Mode dial broken at the shaft
Mode dial broken at the shaft, could ifixit do a video on how to repair it and the tools I need?
I've been looking for a repair video, so far almost nobody does it and only recommend super glues or gasket makers...
So I'll be undergoing that daunting task...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@dilsiam Teh iFixit team really has not a lot of time to create specific requests. There are just to many device and to little time for this. This is where normal users like you and I come in. Most of the guides on here are made by the community. We create those and post them on here. Let's say you start working on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That way the next person that runs into issues with their camera, would have the help they needed based on your guide. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
As for your repair, we really would need to see how the dial broke off. Post some well-focused images of this with your Question. That way we can see what you see. 在已经存在的问题里加入图片 Personally I am not a fan of "super glue" etc. If anything, I would try and use some epoxy resin. I just have more luck using that stuff instead of adhesives. Looks like Canon even considers the Mode Dial a Non Serviceable part Canon EOS450D Parts List
这个答案有帮助吗?
得分 0
4条评论:
Ok, thanks for your answer as far as the mode dial being non-serviceable I have my doubts.
The mode dial popped off from the shaft, so you can't change the mode dial settings for example: Av to say P
I've been doing my research I haven't got to the part of the mode dial being repaired per sé. I do know where to get the mode dial with its shaft...
What I can say about the repair is that it is super tedious to unscrew those teeny tiny screws and disassemble the camera without ripping the ribbons...and without losing the screws and also put them where they were...
You have to get to the top cover where all the buttons are...
完成的
@dilsiam "the mode dial being non-serviceable" I guess what Canon is saying is that the dial is not available as an individual part, hence the descriptor "not serviceable" for the dial alone. Heck yes, this looks like a PITA to do, but it's better than to bin the camera. :-)
完成的
Thanks again @oldturkey03, yes it is a PITA but I'll do my best to do what you said on your answer I have more cameras to take the pictures asked and make an album for the community. Hopefully more people won't have to throw away their Rebel EOS XSia and if it isn't possible to fix it it would have been an interesting and exhilarating trip :-)
完成的
@dilsiam that'll be outstanding. That way we can hopefully have more people keep their cameras. Saves money and keeps stuff out of the landfill.
Repair is War on Entropy!!!!
完成的
添加一条评论
I've taken apart and reassembled a mode dial on a Canon Rebel T3, so they definitely usually can be serviced. However, if you're planning on replacing it, makes sure that you are able to find a replacement mode dial. Alternatively you can also just replace the entire top cover of the camera, which would also make fixing the issue easier. Fortunately, it appears like you'd be able to disconnect all the cables connected to the top cover without the need for soldering (which isn't always the case).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dilsiam 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 66
