跳转到主内容
The OnePlus 8 Pro is an Android smartphone from OnePlus. It was Released in May of 2020.
pink vertical line in screen
There is a pink vertical line in screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Screen lines repair
完成的
@khanikhan same as my original answer
完成的
添加一条评论
1个答案
@keval18229 you are not giving us a lot of history here. We would need to know if anything has happened to the phone prior to this, or if this just all of a sudden happened by itself. This is most likely a bad display. While you open your phone to work on it, double check the LCD connector. Make sure it is properly inserted, does not show any damage, corrosion etc.
Since iFixit does not yet have a specific guide for this, use something like this video replacement screen are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keval 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 210
