跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
Can this Mac be anodized?
I'm fairly interested In anodizing, and had done it on several of my aluminum pens. I no longer needed the Mac and was wondering whether I can make the thing interesting. Can anyone tell me whether this Mac already have protective layers or it's just plain aluminum? By the way, my Mac was silver, so it seemed to be just bare aluminum, but Apple might have applied a protective layer and I don't want to dip the casing into the solution and potentially mess it up before I'm certain it can be done. Huge thanks.
UPDATE: Now I know that there's indeed a protective layer on the casing, can applying the acidic solution without electricity actually remove the layer? Or do I have to grind the thing with sandpaper to remove it? Still hopeful that I can have a green Mac.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Apple applies an anodized finish as you don’t want a raw Aluminum surface as it would rub off onto your skin which can be very irritating!
Buddy Ebsen became deathly ill from the aluminum paint applied when he was playing the tin man in the Wizard of Oz role.
Update (09/12/24)
Here’s an example on what would be needed Removing Anodizing & Polishing Aluminum BMX Hub! (Mirror Finish). Keep in mind all of the plastics and other metal parts will needed to be stripped before you do this.
Maybe it would be smarter getting a replacement uppercase and bottom cover, doing the lid is a nightmare! As you’ll need to take it apart which is risky(unless you don’t do it).
For me I went with skins which adhere to the case parts and if I get bored with a given color or the skin is soiled or worn it’s easy enough to replace with a fresh skin.
这个答案有帮助吗?
得分 0
1条评论:
Thanks man! I guess that removing everything would be hard but I likes a bit of challenge, and I don't actually need the Mac that much. I'll have to decide on a color though. Anyway, Thanks!
由完成的
添加一条评论
添加你的答案
Leooooo1061 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 615
