跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
How to install windows (bootcamp) if I dont have my optical drive?
I will install a SSD drive in my optical bay, and a 500 Gb hard drive at 7400 rpm in the primary hard drive bay on my MacBook Core 2 Duo.
In the SSD be installing the operating system (Mac OS X), but I need to install Windows XP on a partition on the hard disk but bootcamp does not allow the installation from a USB optical drive, how I can do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
1个答案
已选择的解决方案
Go to Applications folder > Utilities> Boot Camp Assistant and set it up.
这个答案有帮助吗?
得分 3
6条评论:
Thanks, yes I know that, but when I'm going to install, the installation program runs and start to load the system files, I get an error and the machine restarts.
I get this error only when Im trying to install windows via USB optical drives (optical units powered by USB and also AC-DC). When I try the installation from the internal superdrive, I dont get any error.
完成的
I hate to ask the obvious, but why don't you just use the internal drive that doesn't give you any errors? Otherwise use a firewire external drive.
完成的
I've already set my Boot Camp, and I used the internal SuperDrive, but... wouldn't one of those external drives with "USB boot functionality" work? I tell that because my CoreDuo, when I boot with my external BD attached, seeks it at boot.
完成的
In response to Mayer, I am replacing my superdrive drive for a SSD, I do to improve the speed of my Mac, which currently do not have enough money to buy a new MacBook. therefore could not use my internal optical drive.
Stefano, I have tried several external optical drives (Samsung, LG, HP, even a modified macbook air superdrive) and all I have the same problem.
And is not the installation CD of windows.
Any solution?
完成的
Aside from following this hint with a reputable external driver certfied for USB booting, I'm drawing a blank:
http://riactant.wordpress.com/2009/02/25...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Sebastian V 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 2,752
