跳转到主内容
加入维修社区 - 创建账户
更大尺寸的 Nintendo DSi,北美市场于2010年3月开售。大多数维修只需要一个螺丝刀和塑料撬具即可完成。
What needs to be replaced?
I’m pretty sure I put the battery in backwards and blew a fuse when turning on my ds while testing to see if it worked as I was replacing the bottom screen. Do I need to replace the battery, the power board, or the entire motherboard? And if the motherboard needs to be replaced does that erase all data on the ds itself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Here’s a YouTube video showing how to restore power to your DS.
https://m.youtube.com/watch?v=MvvCuyreNq...
It’s not a difficult fix but you will need basic tools & the correct gauge fuse wire to complete the bridge on the fuse.
If you don’t have the equipment or tools you may know someone that has or you can take it to a repair shop.
Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mekong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 28
总计 211
