跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Cloudy Screen After Water Damage
My friend forgot to take his iPhone 4 out of his pocket during a swim in the sea. After around 20 minutes, he found out and put it into a bag of rice. I have fixed it with an alcohol bath and deionized water, but the screen is cloudy. The bottom 1 cm has some yellow tint, and the rest of the screen looks dark and murky. Is there any way to remove these, or do I have to replace the screen and glass? Or should I just allow the phone to dry out for a couple of days?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Let it dry out and see what you get. Since you said the sea, I assume this is a saltwater sea, it may be contaminants and residue. There might still be a possibility that you will have to replace the display assembly, but reevaluate in a few days. Good Luck.
这个答案有帮助吗?
得分 1
1条评论:
Ok. I'm doing that right now. I'll come back with the results in a few days.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,130
