跳转到主内容
加入维修社区 - 创建账户
AirPods Max 无线降噪耳机的维修与拆解信息。
Is it a poor contact?
When the right earcup is open, the pairing begins, and if you turn the earcup slightly inward, only the right voice will be cut off, and if you turn it a little more, the Bluetooth will be disconnected. When you install the headphones, the pairing is unpaired from the iPhone.
In this case, is it a problem with poor contact of the hinge hardware?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It sounds like debris on the headband contact pin connecting the left earcup to the right earcup.
Try removing the headband using a SIM ejector tool (This can be found under the ear cushions)
When you pop off the band, the band has what appears to be lightning-like contact pins. Clean those with isopropyl alcohol wipes and reinstall them.
Hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ba_boo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 242
