跳转到主内容
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南,拆解信息和支持文档。本产品型号为 CFI-ZCT1W,主板型号为BDM-010。DualSense 系列手柄取代随 PS4 同期发布的 DualShock 系列手柄。
Left vibration motor automatically pulsates every couple seconds
The left vibrate motor engages (pulsates) every couple of seconds. (Vibrates for about one second every three seconds or so.) Will stop when controller is turned off, but start again upon turning controller back on. Happens constantly whether in a game or not. All software (including controller) is up to date.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi!
This does sound like a motherboard issue. Are any lights on? Or do they stay off?
Does any button work?
完成的
@dan0
Everything else on the controller works perfectly. The buttons and lights are fine. Even the vibration works fine when it’s supposed to. It just has this rhythmic pulsation that constantly happens while the controller is on. I have no idea what is causing it
完成的
Did you tried to complete turn off the PS5 and then to try it on with the controller? Does this work? Did you tried other controllers? Do they work fine? Otherwise it's motherboard related, and thus you need to disassemble the controller to see if there is something wrong..
完成的
添加一条评论
1个答案
Something you can also do is force reset the controller. There's a pinhole on the back of the controller near the Sony logo. Take a straightened paperclip and hold down the button inside that hole for about 5 seconds. It should completely reset everything on the controller, and should fix the issue if it's a software problem. After it resets, take a Type-C to Type-C cable and plug the controller into the Type-C port on the front of the console. It may prompt for firmware updates. Download those and your controller should be back to normal.
If that doesn't fix it, it's most likely a physical hardware issue with how the motor is connected, and you'll have to open up the controller and fix it the hard way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hendrix36 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 37
总计 315
