跳转到主内容
Repair guides and disassembly information for the HP EliteBook 840 G9 laptop. Released in January of 2022.
2 个问题 查看全部
The laptop could not power ON
The laptop could not power ON. I discovered that power is entering from the power pack.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Did you tried a hard reset first?
Please remove the charger from the laptop. Then do the following:
  • Make sure that the laptop is off.
  • Hold the power button for 20 seconds and then release the button.
  • Wait 10 seconds.
  • Now press the power button 1 time.
Now it should boot up again (this can take some time and it’s normal that the LED is flashing).
After this, make sure you download and install the latest BIOS version.
If this failed, you probably need to replace the motherboard to get it working again.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aliyu Isah 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 102
