跳转到主内容
加入维修社区 - 创建账户
适用于支持多点触控的 Apple 无线鼠标的维修指南和故障排除信息。型号 A1657 或 A3204。
Cursor not moving properly
I have bought this mouse around 3 years ago. It worked perfectly well until I accidentally dropped it on a hardwood floor. Since then the cursor won't move well and would move and stop when I move it around. Before dropping it it would work well and I could move it around and it would not get stuck or glitch. Now it's so hard to use it that I started using my trackpad. When I shake it I hear something moving inside it. I need help! This thing cost $100, and I don't want to cause my mom a burden. Anyway, I can fix it myself or is it possible for a technician to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Carefully use a puff of can’ed air into the lens area underneath to blowout any dust which is now blocking the view of the detector. Sometimes the debris is within the light tube for the detector which is not easy to get to or you knocked the detector loose.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
doki ail 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 362
