跳转到主内容
加入维修社区 - 创建账户
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
Model 3 but the factory battery is from model 2
I ordered the model 3 kit, but when I opened my watch, the battery is not the same. I looked at the box, yes I kept it, and it is model 3. However, the battery that the watch has is the A1760.
Has anyone seen this before?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@carlost24430 if your watch has the A1760 battery then your watch is (or at least needs) a Apple Watch 2 (battery). If they shipped you a A1760 then you will have to have the seller repalce it with the proper one for your watch.
Again, if the A1760 is in your watch, it is a Apple Watch 2
这个答案有帮助吗?
得分 1
1条评论:
Thank you for the response. Indeed, I see the problem, though it is too late to return. Ugh.. I ended up buying the battery for the 2, and it should work.
Thank you for your help.
完成的
添加一条评论
最有帮助的答案
Where did you buy the battery? Are you sure the watch is a model 3. Are you confusing the Battery ID with the Watch as A1760 is not a Watch ID. Review this listing EveryMac - Apple Watch specs
这个答案有帮助吗?
得分 1
1条评论:
Thank you for the response. I looked again, and I see the problem, though it is too late to return. Ugh.. I ended up buying the battery for the 2, and it should work.
Thank you for your response.
完成的
添加一条评论
添加你的答案
Carlos T. 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 193
