跳转到主内容
加入维修社区 - 创建账户
Logitech G305 无线游戏鼠标的维修与拆解信息。可通过型号 M-R0071 识别。发布于 2018 年 5 月。
Left Mouse Button not working consistently.
I have had this mouse for 2 years now and have used it intensively daily. About a week ago, the mouse started to have problems registering left clicks. Genarally a few seconds at a time. The mouse still works most of the time otherwise, but it is starting to get annoying.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The basics on how a mouse button works in most is is that the plastic button of the upper part of the mouse presses down on a microswitch that sits on a PCB inside the mouse.
There can be two initial possible causes for this:
  1. A fault in the microswitch that is under the left button. They are rated for a lot of clicks, but eventually they will wear out.
  2. Another possible cause is that the plastics of the mouse may be broken inside and it may not be hitting the microswitch properly anymore.
A good way to check is to open the mouse and inspect the left and right sides if there are any visual differences, or if you see any broken plastic parts or wear, or if directly pressing the microswitches feels different.
While there are no guides specific to this mouse, there a scroll wheel guide, but it will at least show you how to open the mouse and take a look inside: Logitech G305 滚轮更换
The buttons are in the upper part of the mouse casing, the bottom part of the mouse contains the main PCB and scrollwheel.
Take care when opening and don't force anything, mind the cables that connect the two parts.
You can typically open the mouse up enough and still have it active so you can test the switch directly without the plastics.
If you think it is the microswitch, it will depend on how this mouse is built how easy it is to replace this part. From an quick inspection online, you can get whole replacements on sites like AliExpress that just screw in, so no soldering may be needed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Toast 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 89
总计 3,350
