跳转到主内容
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
cartridge push in wrong way
cartridge push in wrong way flashes then off how to fix
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Could you take a close up picture of inside the cartridge slot.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
First things first, the cartridge need to be removed first. Be really careful with this. Also first remove the back cover so that you can also pry to remove it from below. When the cartridge is removed, please check for damage. If some pins are bent or broken, you probably do need to replace the game card reader. Hopefully this is not needed as you do need to solder it out, this can be somewhat difficult...
But, like Daniel said, some pictures would be nice, if possible!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jayeim smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 73
