fan cooling not work
fan cooling not work when the car overheat
Hi,
Not a lot of information here, but if the fans are operating you will need to do some troubleshooting.
The cooling system in a vehicle is a pressurised closed system.
If you have lost water from the system it is possible that you have a leak either from connecting hoses, water pump, radiator or head gasket leaking.
It may help to web search online for “how a vehicle’s cooling system works”
Or “points of failure in a vehicle’s cooling system”.
Other than that, it might be a good idea to visit a radiator repair shop for an assessment.
Hope this helps
这个答案有帮助吗?
Thanks..
The fans cooling only rotated or working when switching on air conditioning with speed no.02 .
connecting hoses, water pump, radiator or head gasket "on leak" & cooling system operated properly.
What about the power is there or not ?
Or relay or fuse is there or not ?
Because it rotated when switching on air conditioning..
这个答案有帮助吗?
I’m sorry, are talking about the fan on radiator or fan on air conditioning inside the car?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 44
总计 436
