跳转到主内容
加入维修社区 - 创建账户
树莓派4是由树莓派基金会开发的一款多功能单板计算机,也是树莓派系列产品的第四代机型。
USB ports are dead
Hi guys. I have a RaspberryPi 4B 4GB (newer version) that had 9V instead of 5V put through the USB-C power input according to owner.
Surprisingly it boots and works, but ethernet and USB ports are dead. I replaced the BCM54213PE and VL805 chips I took from a donor board - ethernet works fine now, but no luck with USB.
I also replaced the crystals next to both of those chips - didn't help either.
Any ideas what else I should check?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Fixed it in the end :) So in total I replaced both chips and also quartz crystals next to them on both sides, then also replaced a diode next to the Ethernet port and USB 3 and two chips that look like filters between the BCM54213PE and PoE.
None of that actually did the trick in full, so then I reflowed VL805 IC and voila - "we have picture" (c) Sorin :D
这个答案有帮助吗?
得分 1
添加一条评论
Did you post your question in the Raspberry Forum area?
I would check the power side of the USB sockets is power getting through? Does a powered USB hub allow the USB device to work?
这个答案有帮助吗?
得分 0
1条评论:
Oh absolutely, thanks, but actually I already figured it out :) thanks for the heads up anyway :)
完成的
添加一条评论
添加你的答案
in_sympathy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 52
总计 984
