跳转到主内容
加入维修社区 - 创建账户
也称为 Crosley Musician 娱乐中心。
CD drawer stuck closed.
Where is the auto release hole located?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @jameshubba14635
There is no release (or eject) hole in the CD unit.
Use a thin flat tool e.g. flat metal spudger or even a suitably thin knife etc and slide it gently under the CD tray, on the left side until you feel the catch release.
这个答案有帮助吗?
得分 1
2条评论:
It didn't work. I felt something catch but which way should I move it? I tried up/down/right/left
完成的
didn't open.
完成的
添加一条评论
Under the disc port there should be gears on the left side use a flashlight and look into the hole and grab something thin hard and long enough to fit in the hole I used a knife but all you do is push the gears and they should start turning and when the disc slider pulls out enough for you to be able to grab it pull it out the rest of the way
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jameshubbard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 55
总计 763
