跳转到主内容
加入维修社区 - 创建账户
三星在 2023 年 2 月 1 日的“Unpacked”发布会上公布了 Galaxy Book3 系列产品。同时公布的还有全新的 Galaxy S23 系列。
Screen Hinge is Loose
Bottom case where the screws go in closest to the screen has cracked, and the screen hinge does not stay where you put it It has about 10 degrees of motion where there is no resistance, and then it stops. Lots of play in the hinge.
Are there parts available for the bottom case? Do I need just the bottom case and that will tighten up the hinges, or do I need hinges as well?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @carlneimeyer
Hopefully replacing the bottom case will suffice and that you can re-use the hinges.
Not totally sure regarding what the model number is for a Book3 Pro 16", but if the model number of your laptop is NP960------, search online for BA98-03666A, to find suppliers that suit you best.
This is the Samsung part number for the base cover for the NP960 models and also for the NP964 models.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carl Neimeyer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 65
总计 892
