跳转到主内容
加入维修社区 - 创建账户
Maytag 洗衣机型号 MVWB765FW 是一款带有深水填充选项的波轮式洗衣机。该洗衣机的容量为 4.7 立方英尺。
F5E2 error code immediately turns off
Mine also does this but when it throws up the error code, it immediately turns off and I have to turn it back on. Maytag top load model MVWB765FW3.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Yes same model I believe. I didn't replace the pressure tube so now it fills and drains. Error code LO. It's going to be easier this time around im hoping. Thank you for the info. I appreciate it very much.
由完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
I found this information at “parts select”
https://www.partselect.com/blog/maytag-w...
It will give you an excellent description of the error codes and what to do.
Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi @teresak52014
An F5 E2 indicates a problem with the lid lock in the machine.
Here's the tech sheet for the washer that may help.
Go to p.20 Test #8: Lid Lock and check if that helps to find out what's wrong.
If the lid lock assembly is faulty and needs to be replaced, search online for W10810403 to find suppliers that suit you best.
Here's a video that shows how to replace it.
Prevents the washer lid from opening during wash or spin cycles by locking it.图片
产品
Whirlpool Top Load Washer Lid Lock Assembly - W10810403
$74.99
这个答案有帮助吗?
得分 2
1条评论:
This tech sheet was a life saver. I haven't taken my machine back apart yet but when I changed the lock mechanism and I took the control panel off, I guess I bumped it but a clear tube/hose was just hanging out. I thought it was some sort of vent to keep everything cool. There's a place it fit perfectly too, but now I have to take my control panel off and put the pressure tube back in it's place not where it looks like it would go. I'm no maintenance person but it is very interesting. Thanks for the information. I greatly appreciate it.
由完成的
添加一条评论
添加你的答案
Teresak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 35
总计 895
