跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A52s 是三星 Galaxy A52 的升级版本。
How to replace a broken vibration motor?
Some time ago I noticed the vibrations of the phone being kind of strange like the vibration motor was loose inside the phone or something. The vibrations rattled even in my hands. Now, however, the vibration is gone entirely. Even when I test the vibrations in the diagnostics panel, I get nothing.
I live in a region where Samsung certified repair shops are in limited numbers. There's only one in my city and they told me that they are not sure if it can be fixed. Is there something I can do to fix it or do I just have to live with it?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
HOW TO FIX THE VIBRATION ON MY SAMSUNG A52s ?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
There’s an ideal iFixit guide for you to follow here:
Samsung Galaxy A52s 屏幕更换
It’s a screen replacement guide which includes steps to remove vibration motor, but you’ll only need to go as far as removing the top mainboard.
The vibration motor isn’t mentioned until after the battery is removed - if you watch the battery being removed he then tells you about the vibration motor at the upper end where the mainboard was removed.
Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daedalus308 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 79
总计 1,842
