跳转到主内容
加入维修社区 - 创建账户
KUGOO KIRIN M3 电动滑板车 | 468WH 电力 | 40KM/H 最高速度。
Replacing flat front tire.
Hello there,
asking for any advice with replacing flat tires. I have an Kuugo Kirin M3 electric scooter that needs new inner tube in the front. Problem is the tire is one hell of a chore to take off.
are these bolts in the picture holding the tire in place that I need to take off? I tried to remove them see what happens but they won't budge, they are so stuck they just strip before moving a single bit, tried to loosen them up a bit with WD40 but no luck
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Good suggestion but those bolts won’t let you remove the axle toremove the tire and inner tube. Maybe the bolt near the axle in your photo
这个答案有帮助吗?
得分 2
1条评论:
Oh i can get the wheel off, the problem I have is I cannot seem to get the tire out. It's just too tight a space to maneuver, and when I manage to get a solid grip under the tire it's so stiff I'm not even getting close to moving it out the wheel.
由完成的 分享
添加一条评论
Hi, if I understood correctly.the first thing to do is unscrew the bolt that holds the wheel, that is, remove the axle. Then you need to fix the wheel somehow. And use his hex key to unscrew the screws, if this does not work out, then you need to heat the screws themselves with a burner, warm up the bolts, since the metal expands when heated and it will be easier to get them out. But you need to do this very carefully so as not to burn the tire...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samwise Thebravee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 480
