跳转到主内容
加入维修社区 - 创建账户
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Air bubbles after changing screen
I`ve tried to change screen on my iphone 2g, which was full of bad pixels. I bought a new one on ebay and followed instruction video on youtube, but after connecting everything back the screen looked like this(photo). What have I done wrong? Can this problem be solved somehow or I have to buy a new screen?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Driver733, I am hoping you replaced it as an assembly, not as individual pieces. If you replaced it as an assembly, contact your vendor. This is a manufacturing defect and ask for a replacement or a refund. this is not something that you have done.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your answer. Here`s the item I bought (http://tinyurl.com/d5h8lfb) The seller told me that it is OEM. Could you please take a look on this item and say if it`s OEM or not.
完成的
It is hard to determine if it is OEM or not. This is something that a lot of vendors are saying. The problem here is that air got trapped when the LCD and the glass were bonded. Poor quality control has become a major issue. Hope this helps, good luck.
完成的
添加一条评论
添加你的答案
DRIVER733 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 700
