跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Dead or Not?
Iphone was put into DUF mode because my screen was not turning on and there was some software problems before but now the iphone will not connect to the computer but it will vibrate if i plug it in to the wall after a few minutes.
Any suggestions ?
thanks !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What software problems did you have?
完成的
the phone was taking a while for the screen to come on.
完成的
添加一条评论
2个答案
已选择的解决方案
Try charging the phone for 1 hour and then reconnecting to itunes, i'd also check that the charging port is clear of gunk too. This may be that the battery is dead or the dock is the problem..if the battery is dead it will not supply enough power to wake the phone when connected to the pc. (the pc only supplies enough power to do small tasks once the phone is on) If the phone vibrates after being on wall charger for a few minutes then it sounds like a battery problem. Charge it and see what happens, if still nothing then I'd replace the battery and the LCD screen and possibly the dock. If you replace the LCD then maybe you can see what's going on...
这个答案有帮助吗?
得分 2
1条评论:
would the battery be dead even know it was charging before ?
完成的
添加一条评论
If you do a hard restart (hold the home button for 5 seconds, while continuing with the press, push the volume down for 5 seconds, keep holding and then top button until it restarts) that should work. If not plug it into a computer, then press the top and home button for about 10 seconds, then release the power button while holding the home button until the computer detects an iPhone in restore mode. Restore the device and it should work.
这个答案有帮助吗?
得分 0
1条评论:
dose not work..
完成的
添加一条评论
添加你的答案
thibault noll 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 534
