跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
identify CPU/RAM/Storage specs from a non-working board
the board doesn't turn on. how can I identify the CPU/RAM/Storage from the board? are there any markings on the notebook or the body itself?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
@garegin like @livfe already mentioned, the easiest way to identify your specs would be by using your computers serial number. It will give you the memory as well as the storage information.
The only other way would be by looking at the memory IC's itself. Each one of the 8GB and 16GB configuration uses 3 different IC's, which leaves you with a total of 6 possibilities. Commonly used IC's are HYNIX, Micron, or Samsung. Apple, in it's habitual paranoid way, may have had those IC's marked with their own part numbers:
333S00125
333S00068
333S00166
333S00126
333S00070
333S00167
those are all LDDR3-2133 BGA178 IC's but are different and not just in capacity.
As for your "SSD" storage, again, you are dealing with NAND IC's Apple commonly uses Toshiba IC's for these (may or may not be marked in the APPLE Way :-) Here are the numbers for those
and here are the locations
The boards with a higher storage capacity do have additional solder points. I do hope that this will help you out. Of course, you could also just post a couple of good pictures of your logic board (both sides and IC covering removed) so we could help you further with this.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
If you are trying to fix your system you’ll need to get ahold of the schematics and board view drawings.
Here’s a primer on how the board is laid out if that is what you are looking for 2019款13英寸双雷雳接口MacBook Pro拆解 reference Step 5.
这个答案有帮助吗?
得分 0
4条评论:
No, I'm not trying to fix the board. I simply want the RAM/Storage specs. But I'm going to sell the notebook as is. Also, mine is the MacBook Pro (13-inch, 2019, Four Thunderbolt 3 ports) model.
完成的
@garegin - Identifying your exact config is a bit tricky as Apple no longer offers system details via the serial number. As it turns out Apple only offered two CPU configs:
- 2019 13” MacBook Pro Core i5 2.4GHz
- 2019 13” MacBook Pro Core i7 2.8 GHz
But the RAM & Storage came a few different setups. Do you still have your sales slip paperwork as that will have that listed. If you can get the system running long enough you can get the details within the About This Mac.
完成的
The CPU is i7 2.8GHz. But the board itself has no indications of RAM/SSD?
完成的
@garegin - The only way is to take note of the chips ID and Google it to see if you can find it. Or if you can find the systems schematics the chips ID will be listed. The RAM is within the SoC module and you could have two or four Flash chips.
完成的
添加一条评论
You can try a Serial number lookup by using the serial number located on the underside cover.
A list of all 2019 Models might help also. Apples site has This model listed.
这个答案有帮助吗?
得分 0
4条评论:
@livfe - EveryMac can’t offer deeper details in the S/N lookup as Apple stopped referencing it within the S/N a few years ago in the newer models from 2016
完成的
@danj Yes but it still helps to narrow down the model in question.
完成的
@oldturkey03 MacBook Air (13-inch, 2017)
Purchase Date: September 2019
Serial Number: FVFZ8BBMJ1WK
That is all I get from that site... Everymac gives 2 models the 1.8 Ghz i5 & the 2.2 Ghz i7
完成的
@livfe perfect. Thank you
完成的
添加一条评论
添加你的答案
garegin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 190
