跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone battery doesn't charge after replacement
Hello,
Just received and installed an iPhone battery and dock connector from eBay in my old iPhone 3Gs.
My old battery was drained way too fast and the dock connector had bad contacts, it was a real nightmare to make my iPhone charge.
After replacing the dock and battery, everything worked fine, the battery was pre-charged @ 50%, and uncharged very slowly compared to the old one, which was just what I wanted.
I started playing games & surfing in 3G to drain the battery, at 20% I connected the iPhone to my wall charger. It was detected and I taught the battery was charging, but it wasn't.
After a hour, the battery was now at 19% and I noticed the logo in the bar above was indicating the iPhone is connected, but not charging!
Could this problem be resolved by just replacing the battery again, or is it a more severe problem? It's my only smartphone, and it's really not the moment for me to buy a new one ...
Thanks in advance for help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Louis, replace your new battery with the old one and see how it charges. IF it charges better than the new one, you know to get your new battery refunded. Should there be no difference in rate of charge, it is your dock connector. Double check your repair and you may have to replace it again. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
4条评论:
I bent the original battery a little, will this cause any problem?
Thanks for help!!
完成的
when you say "a little", what is your definition of a little :-) it might, but give it a try anyway for as long as the battery is not punctured, it should be save.
完成的
I'm so happy, the old battery still works!!
So it's definitely battery related, I'm asking a refund right now.
Thank you so much for help!
完成的
You are welcome. :-) Thanks for accepting my answer, all the best to you.
完成的
添加一条评论
Solution Iphone 4 batter slow charge SOLUTION
Just go to settings > reset > 'reset all settings'
This is the solution to get the Iphone back to normal (quick) charging!! 100% worked for me after anoying 2 weeks of figuring out WHY it charged sooo slow! You won't lose data/contacts. Only WiFi passwords and some basic settings, but this is not a big deal compare to the slow charge problem! Success!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Louis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,828
