I am getting the blue screen of death with a stop code of :
The stop code is unmountable boot volume and computer keeps restarting
@malakian The Boot volume is the partition that holds all of the Windows system and boot files. The error that it gives you; is caused by your computer not being able to access that partition. This can be caused by a failed or corrupted MasterBootRecord, a bad drive, bad RAM, corrupt BIOS etc. Try this
Power on your computer and power it off as soon as you see the Windows logo. Do it three times.
After the third time, Windows 10 will boot into diagnostics mode. Sometimes holding the Shift key while booting will bring up this screen. Click Advanced options when the recovery screen appears.
Select Troubleshoot > Advanced options > Startup Repair.
If the issue persists, proceed with these steps:
Select Troubleshoot > Advanced options > Command Prompt.
When the Command Prompt window appears, enter the following lines and press Enter after each line.
bootrec.exe /rebuildbcd
bootrec.exe /fixmbr
bootrec.exe /fixboot
from here. Let us know the results of this.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 9
