跳转到主内容
加入维修社区 - 创建账户
RYOBI 蓝牙变频发电机 2020款 - 2300 启动瓦特和 1800 运行瓦特。型号为 RYI2300VNM。
overloading with nothing plugged in
Why is my Ryobi 2300 bta generator all the sudden overloading soon as it's started with nothing plugged in, also I noticed that the display indicates that it's pulling more watts to run the same load that it was previously using less watts to run I have replaced carb, sparkplug oil, fuel filter air cleaner and the problem still present
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Do you have the GENControl app on your phone? It might give more information.
完成的
@nest2g Yes ,it only displays fuel level watts used and kill switch function there's no diagnostics option
完成的
添加一条评论
2个答案
这个答案有帮助吗?
得分 0
添加一条评论
Have you figured out any additional information , looks like I have the same issue , id hate to have to tear this thing apart I only used it 4 times
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Alexovich 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 37
总计 786
