跳转到主内容
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
Why does my DS not turn on
Plugging in the DS shows a solid charging light but no red or green light and will not turn on. The battery is working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Ayden!
Most of the time a fuse on the motherboard went down. Please test F1 and F2 on the motherboard with a continuity test. If one of them failed, please replace it. You can also replace the whole motherboard but this would be expensive.
Please let us know how it goes!
这个答案有帮助吗?
得分 1
2条评论:
I have red light and charging, trying to turn on get nothing no green light, battery checked worked fine in another device, F1,F2 and EM10 getting correct reading, so what else could it be? This classed as motherboard totally failed as don't want to waste my time on it if so?
完成的
If you did tried another battery, it's most of the time motherboard related. As you checked the fuses and the EM10, you can replace the motherboard. It's more expensive but will save you some headache and testing!
完成的
添加一条评论
添加你的答案
Ayden Guzman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 101
