跳转到主内容
Oppo 公司生产的手机的维修指南和支持。
oppo reno2f repair LCD touch screen
Oppo Reno 2f Touch screen repair
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
Di bagian atas kiri
Google English translation:
At the top left
完成的
Are you saying your touch screen isn't responding on the top left part of the screen? I always helps if you can be more descriptive with the explanation of your problem.
If that's the case, your fix is exactly the same as the original poster's; replace the screen as described in @oldturkey03's answer.
Apakah Anda mengatakan layar sentuh Anda tidak merespons di bagian kiri atas layar? Akan sangat membantu jika Anda dapat menjelaskan masalah Anda secara lebih deskriptif.
Jika demikian, perbaikan Anda sama persis dengan yang dilakukan poster asli; ganti layar seperti yang dijelaskan dalam jawaban @oldturkey03.
完成的
Up screen not working
How to fix oppo Reno 2f
完成的
Your fix is exactly the same as the original poster's; replace the screen as described in @oldturkey03's answer.
完成的
My oppo reno 2f is a touch problem I think I'm using wifi to no problem but I'm using own network and the problem issue milliseconds for my display black
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
@romancarino your touch screen is part of the display assembly. You will have to replace the complete assembly. Since iFixit does not yet have a specific guide for this, use this video Replacement screens are readily available at many online stores. Purchase from a vendor of your choice.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Roman carino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 23
总计 387
