跳转到主内容
加入维修社区 - 创建账户
The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
Wii U won't read SD cards anymore, can it be fixed?
SO I tried to homebrew my Wii U so that I could play an american copy of a game I have had on my shelf for a while now, but when trying to homebrew the console I saw that i couldn't get it to read any SD cards (couldn't see it on the Wii U, and it wouldn't create a Wii U older on the SD card after putting it inside the console). I pressume that if's just dead and I can't do anything about it, but I thought that maybe someone else over here had an idea / suggestion. Thanks for reading thus far!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Tim!
I can’t help you with modding your Wii U.. but I can help you regarding the SD card reader.
First things first, try to clean the SD card reader slot with isopropyl alcohol as good as you can.
If it still does not ready any SD card, you need to open up the console and check if any pins are bent inside the SD card reader slot, also check for dirt in there! If there is dirt in there, then please try to clean it again.
Last resort is to replace the reader… unfortunately it’s soldered on the motherboard… so, replacing it requires soldering plus soldering skills. If you don’t have any experience with it, then you can bring it to a local repair shop and ask them to fix it for you.
Good luck with the repair, and please let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tim van den Berg 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 148
总计 1,039
