跳转到主内容
加入维修社区 - 创建账户
采用 USB-C 充电盒的 AirPods Pro 2 提升了防尘性能、加快了充电速度,还可搭配 Apple Vision Pro 使用无损音频功能。此外,该耳机还配备了自适应音频、对话感知以及个性化音量调节功能。
Chirping Sounds from Case
Hey guys. Every now and again I wake up and grab my AirPods, and upon moving they begin to make a chirping sound. The light on the case starts flashing (Like Find My) and the sounds are not as loud as those in Find My. Any idea what this could indicate? It chirps for about thirty seconds and then stops once connected to my iPhone.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hello @jadonlyon!
That sound is the sound that AirPods make when they are separated from their owner's device. The idea is if you planted them on someone with the malicious intent to track them, the person would hear the noise every time the AirPods are moved and find them. Obviously, you're not doing that. When it makes the noise, have they been separated from your iPhone for a long time? Is Bluetooth on your iPhone left on? If either of these things have happened, that could be the cause of the noise.
这个答案有帮助吗?
得分 1
1条评论:
@fixer85785 - Thank you very much! I do typically set my phone in Airplane mode during the night, so that would explain it. I did forget that the AirPods case has the same system as AirTag. Thanks for your help!
由完成的
添加一条评论
Pdffyrtttffffftuvhhvg
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jadon Lyon 将永远感激不已
浏览统计数据:
过去 24 小时: 21
过去 7 天: 165
过去 30 天: 638
总计 13,219
