跳转到主内容
这个页面是关于华为在2016年发布的Mate 9的维修指南和技术回顾。
20 个问题 查看全部
Battery Charging Status Abnormal
How do I resolve the issue where my battery does not charge above 60% and brings a notification like Battery Charging Status Abnormal...??
Tried replacing faulty battery still not resolved tried different chargers, nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@wangumwanza the only other obvious thing to try would be to replace the sub board (daughter board) and to check the ribbon cable going from the sub board to the main board. If after replacing those you still have the same issues, then you will be looking toward a board-level repair. Huawei Mate 9 Teardown
If nothing else, take a look on here and see if that helps you after those two other things I would try first.
这个答案有帮助吗?
得分 0
添加一条评论
it's not the battery, it's a bug in the update of EMUI software. Huawei misleading users instead of fixing it.
Backup your phone first, then downgrade to previous version software. problem will be resolved 100%. do not let the phone update automatically
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wangu Mwanza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 107
