Wifi And Bluetooth Not Working
My Wifi and Bluetooth on Fold 5 is not working. it was working up untill now but now it is not working when i click the Wifi and bluetooth button it is greyed out. PLEASE HELP
The phone is most likely faulty - take it into your local store to get it replaced
这个答案有帮助吗?
Its the ribbon cable which is degrading causing the Bluetooth and WiFi not to work
这个答案有帮助吗?
Well update the phone to it latest software version sometime outdated version can also cause this kind of issue.
这个答案有帮助吗?
I have the same issue and tried different software solutions and quite often is starts working out of the blue. Also i noticed when i move or drop the phone then bluetooth gets disconnected so Its most likely an internal hardware issue. I'll be checking furthur how to open the phone carefully and see where the connector is of bleutooth/wifi, perhaps its not connected properly.
这个答案有帮助吗?
Restart your Galaxy Fold 5 first, then reset the network settings and check if Wi-Fi and Bluetooth become available. Booting into Safe Mode can help determine whether a third-party app is causing the issue. If both options remain grayed out after these steps, the problem is likely hardware-related and requires professional service.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 92
总计 1,122
